Clevite Bearing Part numbers
matt92vr4
Venice, FL
Hello, does anyone know the Clevite part numbers for standard siz rod and main bearings for my 1992 vr4 6 bolt? Clevite says the part numbers changed mid year. I am not able to read the manufacture date on my sticker. Thanks in advance.
-Matt
matt92vr4
Venice, FL
From my supplier:
"I have the part numbers, trouble is they are different between 3/92 and 4+/92
so up to 3/92 is one part# then 4/92 t0 12/92 is a different part #
looks like E39a chassis was only built up to 3/92"
Thanks for your help.
kooter
carpentersville, IL
just use CAPS with your vin and it will tell you the build date.
If you do not have access. just pm me your vin and I will check.
matt92vr4
Venice, FL
Good call! I downloaded CAPS and plugged it in. 08/91 Thanks!
That is the 6 bolt/ 7 bolt break point. AS far as has ever been discussed here, no US GVR4s were ever made with 7 bolt engines from the factory.
Quoting matt92vr4:
From my supplier:
