I've searched everywhere and can't seem to find a definite answer...
My tuner set my idle at 1000rpm and i am seeing 12-13 degrees timing via Ecmlink. Should the timing be set at 5BTDC regardless if its at 800rpm or not? I've been having stalling issues coming to a stoplight ever since the tune, hence why he raised the idle and the coasting offset. But it didn't solve my problem. I checked for leaks, cleaned the t-body and changed the seals, delete fiav and tested the isc already. Need some info fellas or this thing will sit another 5yrs in the garage.
