Head bolt question.
birdman24
Cleveland, Ohio
What size allen socket is needed to remove the head bolts?
Terence
donniekak
surprise az
Quoting PreskitVR4:
Buy two.... At least one will break before you get them all off!
Are you sure you weren't using an allen wrench? The 10mm allen sockets are next to impossible to break.
Barnes
Richland, WA
Quoting PreskitVR4:
Or buy one high quality one.
PreskitVR4
Prescott, Northern AZ
yes, mine came off the snap-on truck, after countless parts store failures /ubbthreads/images/graemlins/smile.gif
89Mirageman
Stantonsburg, NC
Granted I've only pulled 5-10 cylinder heads off with mine but the one I got from Sears is still holding up. But now that I've said that I'm sure it will break the next time I use it. /ubbthreads/images/graemlins/grin.gif
Chad989of2000
Livermore, CA
What????? We are talking head bolts right? They should only be torqued down to 72 ft/lbs...definitely not tool destroying specs.
tsiboy
Los Angeles, Ca
I always worry about screwing up the allen head of the bolt more than breaking the socket. make sure the socket is all the way in!!! I have had a few close calls in the past
AnotherNewb
Orlando, FL
I usually break the allen insert out of the socket and have to tack weld it back in... great neck ftl /ubbthreads/images/graemlins/grin.gif
birdman24
Cleveland, Ohio
Thanks for all the replies and advice guys. I got the allen socket on Wednesday and took the head off on Thursday without breaking anything.
Barnes
Richland, WA
Quoting Chad989of2000:
The original poster said for removal, and I'll agree they can be a huge pain to remove. All that coked on oil can really glue things together.
