aws light
Today as I was driving to work I noticed my aws light was on. I stopped and turned the car off, then back on and it shut off. The light would come back on any time I took a hard right turn. I'm new to the gvr4 and not really sure where to start with fixing this aws problem. I tried searching, but the search function on this forum never seems to give me much luck.
I've read up on a lot of ppl just taking out their aws, and honestly if that's the easier solution then I wouldn't mind just doing that. I hardly even notice the aws kick in anyways.
Thanks in advance,
-Brian
Struc
Oconomowoc, WI
Your fluid level is probably low.
SouthCaliVR4
North county San Diego
The light is attached to a level sensor in the fluid res. as stated your probably just low on fluid. be sure & check the system for leaks.
Cool I'll check the fluid level at lunch. Thanks guys I totally should have thought to check that first.
Dasith
Melbourne, Australia
hi
where is the fluid reservoir??
SouthCaliVR4
^^ drivers front, next to the timing cover end motor mount.
Edit: passenger side for you /ubbthreads/images/graemlins/blush.gif
