AuSpecVr4
Hey
I have been having this problem with my clutch slave for a while now since i built my new motor and put a new clutch in.
The clutch is a 6 puk brass button that was bought of eBay. It was installed and when the clutch pedal is pushed it was soft up top then really hard down the bottom and when trying to release the pedal slowly it would pop out fast from the pressure. The clutch is just on or off. Assuming that was the puk clutch i have been driving it around for a month or two now and had a drama last week.
I was driving around (street, casual driving) and my clutch all of a sudden would go soft and there would be 1cm of travel at the bottom of the clutch where it would engage. The top was all soft, so i would pump it lightly so it would return to normal. I then went from second to first causing the pedal to just go dead to the floor, it had nothing. The push rod had snapped and pushed the cylinder out of the slave along with all my oil. I managed to limp it home without a clutch to change gears. It was repaired by placing a bolt of similar size in it and had been fine for a week. The rod was longer then the original because that seemed to be the problem because it was pushing the rod to far and pushing the cylinder out.
Now on the way home again i thought i snapped the push rod (homemade) and as i got home to have a look i see its been pushed out. Is this a problem with the clutch assembly? Also sometimes i would hear a noise coming from the clutch area when the clutch would be pushed and sometimes when i started the car without the clutch pushed.
Has anyone had this problem and what do you suggest i do? if i end up having to take the box out can it be dropped if the cross member is removed so the engine can stay in the car?
Cheers, Brock /ubbthreads/images/graemlins/cool.gif
