Trans mount bolt thread?
Brunoboy
San Bruno,CA Home of SFO
I need to know what the thread is for the trans mount to trans.
Brunoboy
Lowes doesn't have it, anywhere have it???
Hard to find these, as most here use ISO instead of JIS, so they will be 12 x 1.5 or 1.75.
Have an Orchard Supply nearby?
Brunoboy
I do have an Orchard supply, ISO JIS? The reason being is after i switched the trans my old bolts didnt fit in the new trans, and I have no idea why. /ubbthreads/images/graemlins/dunno.gif
89Mirageman
Stantonsburg, NC
Sounds like the threaded holes on your new(er) tranny are stripped. Pretty much every Mitsu that I have seen from that era has the same size bolts holing the tranny mount on. There should be enough material there to drill/tap if thats the case. Or maybe a slightly longer bolt. I think the ones that hold the cam gears to the cams are a little longer.
Brunoboy
The bolts I have from the older tranny are bigger than the holes in the new tranny.
89Mirageman
Stantonsburg, NC
Hmm, that's weird. Is it a 2g dsm tranny? If the bolts are smaller I would guess 10mm 1.25 thread pitch.
Brunoboy
The wad of the bolt is a 17mm, I don't think it's an oem bolt in the first place, and not sure about it being a 2g tranny. The new one is from uncleben on here and it's a tre stage 2.
-shane
89Mirageman
Stantonsburg, NC
Can you post some pics of both trannies? Also the bolt that fits the old tranny?
Brunoboy
I bought two 12x1.25 30mm from lowes and added two washers a piece and it works. thanks guys. The other bolts I believe at 12x1.50/.75 retapped...
89Mirageman
Stantonsburg, NC
Glad you got it sorted, I know something didn't sound right.
Brunoboy
My front trans bolt doesn't thread now -____-
Brunoboy
Got one that was listed on vfaq for thread pattern didn't work, went to the junkyard and it was correct.
-shane
