help:misfire issues
oldman_tau
cerritos,california
i have a problem with my galant...i already replaced my spark plugs,wires,coil and ecu still has a occasional misfires gas consumption is high...somebody told me it might be the injectors or tr unit that controls the coil. any inputs would be appreciated.
by the way, i have a galant gsx.
ktmrider
Tempe, AZ
TR and injectors could be an issue.
Also check the fuel pressure regulator, poor fuel economy and misfires at high(er) RPM's are common ( pig rich at idle, lean at higher RPM's ).
rgeier11
Chicago Suburbs, IL
You may have a bad coolant sensor or o2 sensor. Use a datalogger to check what values your ECU is seeing.
Struc
Oconomowoc, WI
ECU CAPS been replaced?
