First of all, which is better - 1GA or 1GB?
I live near Watkins Glen and hope to someday get into road racing. I want to do the ABS delete for obvious reasons. But I'm worried that the prop valve I choose will decrease my braking performance. Or if I really choose the wrong one, would I ever run into rear lock-up on the icy roads I drive on all the time?
I'm looking at this chart now:
It looks like the AWD Galant prop valve has the highest split point. If I am interpreting this correctly, it will take more brake pressure to decrease pressure at the rear brakes. So by comparing all of these valves in the same vehicle, our stock valves will stay 50/50 with a little bit harder braking than the others. So anywhere that the blue line is above all of the others, this valve is more rear-biased than the others. I'm not sure what pressures are normal for road racing, but I think where the lines start to cross, we're getting out of typical range, even for racing(I could be very wrong, I guess this is an important thing to know). So if this valve was used in another chassis that normally uses a more front-biased valve, you could potentially experience rear-lock under hard braking. If we use a valve from another car, it will be even more front-biased than our forgiving(safest, lowest-common denominator) stock valve and stopping distances will go up because our rear brakes aren't doing anything. I'm just trying to get the most performance out of the system that I can.
All of that analysis was basically for braking pressures below 1100. So...if they do get higher than that, everything changes. So like I said before, in order to use this chart effectively I need to know what kind of pressures are normal for various operating conditions. I don't know that much about brakes, I'm trying to learn before I get the 1g AWD valve just because everyone else does it and it "works".
