Do you guys know if the stock ecu needs a air flow meter reading in order to operate?
I'm trying to use the stock ecu to control idle only.
This means
- ac relay output
- ps switch input
- ac switch input
- stepper motor control
- idle stop switch
I've also wired in speed and cas signals to let the ecu know that it is up and running.
I've got a Motec M4 (basic) ecu to control fuel and ignition + boost.
So far the stock ecu is not doing with the idle control.
Also when I gnd the timing pin, the stepper motor doesn't react at all, should it reset when this happens?
