differences between cyclone manifolds?
Brunoboy
San Bruno,CA Home of SFO
I have seen two different types of Cyclones, Whats the difference between:
and
FlyingEagle
THE Ottawa
Which title do you prefer?
Cyclone Turbo Intercooler
or
ECI Multi Turbo Intercooler
I picked the ECI model as no one would ever suspect it was anything fancy.
There is absolutely no difference between the manifolds. I'll wait for some more people to chime in,
but it is the AMG NA manifold and those turbo manifolds above, that are indeed the 2 different types.
There is only "one" turbo manifold, 2 different name plates were cast in and were available on different models.
Hope that helps your decision making process. /ubbthreads/images/graemlins/grin.gif
Brunoboy
ok, i picked up the ECI one.I was just wondering since it looked different. or stamped different. Did you notice a difference in torque with your manifold?
Mine was on a an adjustable hobbs switch and yes I could tell a difference.
Do a search on here maybe in the How to's I posted a DIY activation deal built from junkyard parts. Total cost should be between free and 5 dollars
Brunoboy
I am going to use ecmlink v3, these are two piece intake manifolds correct? And gaskets can be made for it out of gasket maker?
Struc
Oconomowoc, WI
JNZ just posted that they got some gasket kits back in stock.
kitcho
canada
Newer JDM galants like mine have the ECI Multi lettering. Earlier JDM galants had the Cyclone lettering. As already mentioned, there's no functional difference.
According to Mitsubishi ASA, JDM VR-4s made from 1987 - July 1990 had the 'Cyclone' lettering. Subsequent VR-4s (August 1990 - March 1992) had the 'ECI Multi' lettering.
Brunoboy
thanks for the info, also yes i saw that jnz carries the gaskets, but I was wondering if it were possible to make a gasket? or is anyone using a home made gasket? I am strapped for cash at the moment and if i were able to make one great, if not, 60$ will have to wait a bit.
Struc
Oconomowoc, WI
I don't see why you couldn't make them. I always keep a roll of gasket material in my garage myself.
DR1665
Iowa City, IA
I, too, saw JNZ carries the gaskets. As much as I would like to support them (heard nothing but excellent things), I can't justify spending $60 on intake manifold gaskets. I'll be making my own.
beaner
b'ham, mi
Aside of the headgasket and exhaust manifold, I've made every single gasket in my engine including for the cyclone. No issues.
Brunoboy
What's the best gasket maker material? And how easy is it to make one? Whats everyone using as a vacuum canister?
dsm10o0
San Jose CA
I got alot of sheets to make a gasket.
Brunoboy
Quoting brunoboy:
bump for answers, and btw, there are no ports for EGR and suck correct?
thedsmguy
Vancouver Washington
Has anyone ran a cyclone without the valves? I've ran into a few that didn't have the actuators etc and always wondered what if you just gutted it and left it alone, would it act kinda like a large plenum intake or would it screw sh*t up?
Brunoboy
without the valves the intake manifold is pointless.
Brunoboy
Quoting brunoboy:
Quoting brunoboy:
anyone that can answer both of these questions for me?
Id just get the semi thickest gasket paper you can find, the secret is to take a socket thats kinda heavy, tape the paper to the manifold and then tap the edges of the runners and the outside of the manifold with the socket and it will make an impression and sometimes just make the cut for you. then take a razor blade and cut the rest out.. take your time. it works fine as long as you evenly tighten your manifold down. and use a little sealant on both sides for the water.
Brunoboy
theres no water in the IM? Can I copper spray it?
beaner
b'ham, mi
Do not use copper spray on the composite gasket. Just the gasket is fine so long as both surfaces are clean.
