Ac fan won't kick on when I turn a/c on. Help please
cupajoe
Cocoa, FL
Ok little back ground, for what ever reason I had the a/c fan wired to run when my radiator fan would run because I never used ac till now. I decided to wire it back up to how it was originally and in the process I got a spark from the power wire and I think I might have popped a fuse? The fuse under the hood looks fine. Is there any other fused or relay I would have popped?
cupajoe
Cocoa, FL
What should the reading be on the ac temp fan switch located on the lower t-stat? I got 115 ohm with the car warmed up. Can someone verify if that's good or bad? Thanks.
cupajoe
Cocoa, FL
Does anyone know where the Radiator Fan Motor Relay is located?
Thanks, joe
cupajoe
Cocoa, FL
^ Thank you. Found it.
