transmission and transfer case fluid
Brunoboy
San Bruno,CA Home of SFO
I made a thread way back when about fluids, what is everyone running in their tranny and transfer? i know someone used to mix redline mt90 and the shock proof or something. So whats up? I am getting a new tranny soon from a local and I dont wanna mess it up. lol
-Shane
Barnes
Richland, WA
Have you tried searching?
Tre3zy
South San Francisco, CA
^ /ubbthreads/images/graemlins/rofl.gif ive been trying to tell him that for years...
anyways i use a mix of MTL and MT-90 for trans and HEAVY DUTY SHOCKPROOF for Tcase
Tre3zy
^ is that for both tcase and trans? mmmm maybe ima try that....
1qkfwd
Sun Valley, NV
I run straight MT90 in the trans and shockproof in the tcase. No need to mix unless your making alot of torque.
PreskitVR4
Prescott, Northern AZ
^^^^ he said what i was gonna said. many years of abuse happend in my Talon with this combo. To clarify, redline shockproof RED, not blue. blue is lightweight, not as good in my experience. good for the rear diff tooo.
Quoting Tre3zy:
Pretty sure you could, but it's expensive. I run shockproof in the xfer case and rear end instead.
Brunoboy
Quoting Barnes:
Nah waste of time lol, jk but seriously I don't remember What the title of y thread was because it had nothing to do with fluid, it just happened to go there.
Quoting 4thStroke:
At the rate I pull my tranny, I refuse to run NEO RHD anymore. I feel bad about reusing tranny fluid.
Unless I have some internal tranny catastrophe, I have no problem reusing the stuff. Too expensive not to, IMO. I just make sure to drain it into a clean container.
4thStroke
Vancouver, WA
I agree with you, Mark.
It's just that I could have a catastrophic failure at any given time, and there's a good chunk of money in tranny fluid down the drain (again).
Barnes
Richland, WA
But you have to ask the question; would that tranny fluid help prevent said catastrophic failure?
Yes. But at some point, the best fluid in the world won't keep the power our modified engines produce (some of us a crapload) from blowing the teeth off our gearsets, amirite?
1qkfwd
Sun Valley, NV
You be surprised on how much torque it take to pure strip teeth off a properly preloaded gearset. Our trans it's the 4th and it will straight shred teeth.
Barnes
Richland, WA
Quoting turbowop:
Perhaps Spencer is beyond this threshold?
4thStroke
Vancouver, WA
I was running the NEO RHD cocktail that English likes when I shredded a fresh 5 speed. The car made 557whp, 455ftlbs on the dyno and it was turned down a couple pounds for street duty. I won't lie, I beat on that tranny, it lasted 6,000 miles or so. I ripped 3rd apart, which then took out the rest of the tranny.
The car is back on pump gas, making 440whp/335ftlbs, so it's a lot safer, but I'm still a bit worried about the longevity if I decide to take it to the track.
I run MT90 now. It's easy to get and is a bit cheaper than NEO. I don't think MTL, MT90, NEO, or anything in the correct weight will save a tranny. It would be such a thin line being toyed with, it'd only be a matter of time until the gearset is fatigued and lets go. Synchromesh won't offer the protection, and heavyweight can send paraffin into the oil ports and may have adverse affects on shifting, although I never did try something this heavy in my tranny. I don't think even the heaviest oil will be the saving grace.
I dunno, some people can get away with abusing an old stock transmission for years, where others are breaking HD gearsets in no time.
Brunoboy
Quoting 1qkfwd:
my tranny is currently stuck in 4th. and wont shift out of it.....
You probably broke a shift fork then, which has more to do with human power and nothing to do with horsepower. Did you slam it into gear or force it too hard a few times?
Brunoboy
maybe... /ubbthreads/images/graemlins/hsugh.gif
