3G brake master cylinder?
524of1000
San Antonio, Tx
The infinity Q45 master is an upgrade as well. Needs tome of the brake lines bent, but works quite well.
CutlassJim
Manchester, NH
The 3G master needs a brake line bent as well and the reservoir is VERY close to the strut tower. The 2G needs to be a V6. Also applicable are early 2000 Galants, Stratus', and Sebrings with the 6G72 but ALSO with the dual caliper brakes so you get the 1 1/16 master and not the similar to what we already have 1".
RedTwo
New Zealand
Evos work - however from the 7 onwards the clutch is also fed from the brake master cylinder, so one more port that you need. The Brembo equiped Evos (except the E5) and GTOs are 1/1/16" or 17/16" diametre if you prefer. The VR4 is less than 1", around 6/7" IIRC.
You can't use the brake boosters from Brembo Evos (8+9" IIRC - damn it!) but the master cylinder bolts right up. You may have some trouble accessing the reservoir if you have a front strut brace.
I personally have one from a 6.5 Tommy Mak /ubbthreads/images/graemlins/devil.gif /ubbthreads/images/graemlins/grin.gif
