Quoting Red_Bird:
He won't be in boost at idle. May be a vacuum leak, which is what I'm sure you meant to say, but he mentioned nothing about a rough idle. Vacuum leaks can cause high idle, but you more than likely to notice the rough idle it causes before you the notice the high idle.
Boost leaks, vacuum leaks, whatever. I've had them cause high idle without roughness more than once. /ubbthreads/images/graemlins/dunno.gif
