What would cause this (PCM failure):
This doesn't look like the typical failure-mode for these PCMs, any idea what would cause this? I think it's something related to the injector drivers since they weren't pulsing and we found the PCM like this while diagnosing.
Thanks,
TJ
donkeylips
Rochester, NY
I'm no ecu expert but it looks like your ISC motor is shorted and took out your ISC drivers. I've had this happen a few times, and it's a common way that something wrong with your car can take out an ecu. I'm actually about to buy an eprom that has sustained this damage but still works fine with no ISC. Your FSM will tell you which pins to use to check the resistance of the ISC coils.
So I'm a domestic gear-head at heart (600RWHP NA C5 Z05 track car) and don't know what "ISC" is. /ubbthreads/images/graemlins/frown.gif
Thanks,
TJ
Idle Speed Controller. It is a small motor that is mounted under the Throttle body inlet that has a 6 prong square plug.
Here is a pic that should help you test your unit. If it is bad, you DO NOT want to plug in a new ECU (Engine Control Unit), what you are calling a PCM, without leaving the ISC unplugged until you get a good one.
You should have around 30 ohms of resistance on each coil. An open coil is bad but will not hurt the ESC. A shorted coil is bad and will hurt the ECU.
Thanks Terry... I guess I need the testing specs for the ISC... and probably a new ISC too. Yay.
-TJ
jepherz
KC, Missouri
I think the specs are on VFAQ, although all you need to do is check the resistance of each of the 4 coils in the picture above. They should be all around 25-30 ohms, give or take. It's obvious that one of yours is going to read close to 0 ohms.
holeshotmoe
MD
Found this on DSMTALK:
IC104 is MAF reset (turbo only)
IC105 is ISC coils B1 and B2
IC106 is Boost Control and Fuel Pressure solenoids(turbo only)
IC107 is ISC coils A1 and A2
IC108 is Purge and EGR solenoids
IC109 is A/C and Fuel pump relays
...and the following in THIS THREAD here:
Just for future reference on turbo ECUs:
M5269L low saturation output drivers labeled IC104-IC109:
IC104 is MAF active reset filter (pin 1) (turbo only)
IC105 is ISC coils B1 (pin 7) and B2 (pin 1)
IC106 is Wastegate (pin 1) and Fuel pressure solenoids (pin 7) (turbo only)
IC107 is ISC coils A1 (pin 1) and A2 (pin 7)
IC108 is Purge (pin 1) and EGR solenoids (pin 7)
IC109 is A/C (pin 1) and Fuel pump relays (pin 7)
The pins are the outputs the M5269L driver, matching inputs are 3 and 6
So it does look like IC105 cooked due to a shorted ISC. Had this same issue on one of mine. Also, your picture seems to indicate possible damage to some of the other traces on the board. There's a few guys here that do repairs, and a few may have a spare IC. I've heard of someone salvaging IC108 because they had removed the smog control components from their car, since it wasn't being used. But you had better check with some of the guys that fix these things (e.g., keydiver) first. But if you get one of the chips, a tv repair (are there still such businesses?) shop should be able to solder it in for you, and should be able to repair any broken runs on the board.
