gold relay under glove box?
Anyone know what that gold relay box is for? It started clicking out of the blue. Sorry if this was a noobie question.
I think its the ac fan control unit do you have a pic?
Does it look like this? Wait you said gold scrap that post a pic of the unit
Diego
Willing to bet its MPI...... if your car starts acting funny then we'll know.
He said its under the glove box thought the mpi fuse was in the engine bay??????
Diego
There is one under the dash, next to the ECU iirc, my brother had to replace an MPI relay, due to cutout boost, and lack of engine power. Replaced the MPI relay* and rewired it ( PO hacked it up and put it on a switch ) and hasn't had that problem in a long time.
*Fixed.
toybreaker
iconoclast
Have you inspected the ecu for damage/evidence that the caps have been replaced?
A clicking/noisy mpi relay is often caused by an ecu that has an acid damaged board that can no longer control the fuel pump leg of the mpi relay reliably.
Might not be a bad idea to pull the ecu and take some pics of the board. /ubbthreads/images/graemlins/smile.gif
TB is more than 99% likely to be correct here.
Near Seattle, Washington
Quoting toybreaker:
+1
And that gold thing you're talking about is definitely the main MPI relay. I had some issues with mine, once. Part of the connector had gotten hot at some point and had trouble making contact. Check the contacts and plug on that as well as your ECU.
