Signs of a bad alt? Or starter
Brunoboy
San Bruno,CA Home of SFO
Today my windshield wipers didnt work and its raining,, also my headlights flicker if i dont keep revs up. My car doesnt have enough power to start the car unless i jump it.
RedTwo
New Zealand
Flat battery probably caused by a dead/dying alternator /ubbthreads/images/graemlins/grin.gif
Brunoboy
can there be a bad alt even if the battery light doesnt come on?
toybreaker
iconoclast
yes
Brunoboy
How long does an alt swap take? Its been awhile since ive done that.
gtluke
dirty jersey
I think my alternator light came on like once out of the 8 that have died on me.
raptorWagon
Oak Harbor, WA
Quoting brunoboy:
If you don't have power steering, about 20 minutes. /ubbthreads/images/graemlins/grin.gif
Brunoboy
Lol, i have power steering
RedTwo
New Zealand
You *can* do it without pulling the radiator but I've always found it easier with the rad out of the way. It shouldn't take more than an hour...
raptorWagon
Oak Harbor, WA
That's why I said if you don't have PS it won't take long, never have to touch the radiator to remove the alternator.
Brunoboy
yea I jump started the car today to move the car, and it wouldnt start by itself. This week I am JSB since its raining, I have to do the alternator, the Starter, Panda the bottom half of the car. Turbo Swap. Oil Change, Rear diff needs to be sealed at the drain bolt and the Transfer case drain bolt leak. Redo some wiring, make a FMIC Bracket, clean my fogs, reinstall, paint my roof and do my evo suspension. This is going to be a long week.
Diego
Me and Justin ( well justin did it, I oogled his engine bay /ubbthreads/images/graemlins/grin.gif ) did it collaborativly in about 15 mins.
Then we hit the carrier bearings......... a few minutes. /ubbthreads/images/graemlins/smirk.gif
Brunoboy
it took you 15 minutes to do the swap?
Diego
Yup, got my UIC outta the way, slipped belt off, undid bolts, unplugged, replugged, rebolted, tighten belts, connect UIC, tighten IC silicon couplers............ Done.
KungFu skillz.
Brunoboy
Geez, you still have ps?
Tre3zy
South San Francisco, CA
Quoting Diego:
KungFu skillz.
^ /ubbthreads/images/graemlins/rofl.gif ^
KiNgMaRtY
Corona, CA
Its tough to get it out with the radiator still in. I removed the radiator and moved the PS out of the way got that sucker out. Not the funest, especially the first time around. So much easier on a 1g
Hondakiller
Deltona Florida
The alternator is most likely no good and it killed your batt. So I would get a new alternator a batt. It should fix your problem! /ubbthreads/images/graemlins/cool.gif
Brunoboy
My battery still powers everything on, so i took it out and charged it in deep cycle
