Is this a plate or viscous front LSD?
MX4
New Zealand
Hi all,
I pulled this from a JDM Galant VR4 gearbox. I dont know whether it is plate or viscous. I had trouble getting the 3rd photo in focus however you can make the teeth out inside of the housing. Can someone please advise.
Cheers!!
Uploaded with ImageShack.us
belize1334
Bozeman, MT
Is that an OEM front LSD for an AWD gearbox? Is it compatible with USDM transmissions?
RedTwo
New Zealand
The VR4 RS front LSD unit has the same part number as the CD/CE9A Evo front LSD units, which are apparently viscous. Your car (if it's the one from the FS thread) has a LSD gearbox, so it *should* be a viscous one.
What are the teeth inside the center shaft like?
Near Seattle, Washington
You can't use that. It is useless.
You should give it to me. /ubbthreads/images/graemlins/devil.gif
EDIT: kidding aside.. why does it have a SEALED bearing on it? Are all the LS Front Differentals like that? anybody know?
turboaddict
Omaha, NE
Mitsuturbo there is one in the for sale section if you are looking for one. I know the guy. he is local to me and a friend.
