Custom Radiator
dsmtalontsi95
Glenville, PA
I'm going to be putting the galant back together here soon. I'm not running a water pipe in front of the block so I had a an fitting welded directly to the water pump, same for the t-stat housing that has the cap on it. I would love to put it under the bar that runs along the top of the head lights, like the sccrico radiator. The problem is I want to have the lower pipe bung on the radiator on the drivers side. Does anyone know of one that will fit what I'm looking for?
TylerAdamson
Iowa City, Iowa
Afco offers many different configurations for radiators. Type in Afco in the search on Summit and browse through there.
dsmtalontsi95
Glenville, PA
I don't see on that is 22"w X 13"h and cross flow.
AWDnoobie
Alberta, Canada
DO you have a sirocco rad already? hmm, cant figure out how to say this but anyways, if you got a aluminum rad, why dont you get some one to weld the hose connector on the side you want?
dsmtalontsi95
Glenville, PA
I don't have one but that is a good idea.
*EDIT* sorry but aren't those set up to run both outlets on one side? So if I did that wouldn't that leave 1/2 the radiato not used.
Muskrat
Lexington, KY
Go to click and search for radiator. Buy one that fit's dimensionally and has inlet/outlet where you want. Problem solved.
AWDnoobie
Alberta, Canada
I have a sirocco rad, got it from a guy that was using it in a colt. Ill get some pictures of it on the weekend, if you want to see where and how it fits. I figure using that will give me a few inches of extra space to work with when needed.
