dsmtalontsi95
Is there a way to I.D. the compression ratio with out the paper work? I bought a motor with a bad piston (JE) so I'm swaping blocks. The problem is what comp ratio is it? I can see the boar on the inside of the piston but nothing at all about comp. It says JE on the inside along with 85mm.
*EDIT* Sorry, it's weird this is happening to 2 different people at the same time.
