Tie Rods
KiNgMaRtY
Corona, CA
I am taking my car to have it aligned and I disconnect the REAR tie rod ends so it can be done properly. Its seems that my rear inner and outer tierods are shot on the driver side so I ma aswell replace all of them. Y can't seem to find either rears? Do they use the same as the front for the outer tie rods? How about inners? Also wondering how to replace the inner tierods?
Adorsey
mass
How do you know your rear tierods are bad? Are you sure, or do you know for a fact? I would check the rear wheel bearings for play in them first.
Youre going to have to search for the rear outter links for a part #. I dont think there is inner rear* tie rod ends, I beleive its just the pinion/piston thing.
Front tierods are not bad to do, simple really. Untill you want to do the inners. Like I said again you might want to see/check if its youre wheel barings first. Before doing the hardest thing you could do.
I had the rack and pinion out when I took off my inner tie rods, and they unscrew lefty loosy righty tighty tighty. There is just a metal piece at the end with flat spots on each side for a wrench or vise, to turn the rod in either direction.
Quick view of the front rack.
KiNgMaRtY
Corona, CA
The tie rods have plenty of play on the left. It will wiggle around with little to no effort when I pulled it out and put it to the side. The right one is a little stiffer. The boots on the ends are torn as well on both sides. I did the fronts outers before but have never done iners. So they just "screw" in, sounds easy enough. Now to find the parts.
Adorsey
mass
Depending on if they got loose, It does say they have 50-70footlbs. So it might have to be worked a little to get off, but yeah they "screw" off.
KiNgMaRtY
Corona, CA
I am having the hardest time trying to locate the rears /ubbthreads/images/graemlins/frown.gif.
Mitsu doesn't make them anymore either
Try looking under the 3000gt at rock auto or something. They are the same.
KiNgMaRtY
Corona, CA
Thank you for the advise but I searched and no look either /ubbthreads/images/graemlins/frown.gif
