NateCrisman
Tomorrow night Im going to hit the local dragstrip again, island Dragway with the following plan:
[*]work up to .052 nitrous jet (currently running .037 and have a .042 as well)
[*]start transitioning to Methanol fuel. Planning to mix in with e85 starting with 12.5% and mix in more and more Methanol each run in 1/8 gallon increments until I run out of delivery capacity (or blow something up) [/list]
The car has a 1gallon fuel cell and currently eats about 1/2 gallon of E85 per run on 950cc injectors at 80%DC and 40psi base pressure. On E85 I shoot for a "gasoline AF" of about 12.0:1 and I realize that I'm going to need to target a much richer A/F as the methanol percentage gets higher (down in the 9's at 100%?)
Simple to drain the fuel cell between runs so it should be relatively easy to mix fuel in 1 gallon increments and keep track of the ratio every pass.
Any tips, suggestions, comments, or advise? Should I run a hotter plug or tighter gap?
P.S. Here is a little chart to clarify the Alcohol vs. Lambda vs. Gas numbers
Alcohol Lambda Gas
6.4 1 14.7
6.2 0.96875 14.240625
6 0.9375 13.78125
5.8 0.90625 13.321875
5.6 0.875 12.8625
5.5 0.859375 12.6328125
5.4 0.84375 12.403125
5.2 0.8125 11.94375
5 0.78125 11.484375
4.8 0.75 11.025
4.6 0.71875 10.565625
4.5 0.703125 10.3359375
4.4 0.6875 10.10625
4.2 0.65625 9.646875
4 0.625 9.1875
3.8 0.59375 8.728125
3.6 0.5625 8.26875
3.5 0.546875 8.0390625
3.4 0.53125 7.809375
3.2 0.5 7.35
Alcohol Lambda Gas
6.4 1 14.7
6 0.9375 13.78125
5.6 0.875 12.8625
5.2 0.8125 11.94375
5 0.78125 11.484375
4.8 0.75 11.025
4.4 0.6875 10.10625
4 0.625 9.1875
3.6 0.5625 8.26875
3.2 0.5 7.35
