Few miles after rebuilding my engine, it start to burn oil, it happened to me long time ago for short time, so i decided to use the car and see if it was the same thing but this time problem became worse, and decide to remove head and check for problems. When we did that, piston # 1 from flywheel, was covered with oil and look like new, others 3 pistons were black covered with normal combustion residues. However, all the cylinders was marked on the back side like if the rings were doing more pressure there. The mechanic said the rings was the problem and we change them for a new ones, cylinders were polished to recover the normal surface appearance. Head got new valve seals and engine was built again. When we started, few minutes later it started to smoke again, blue smoke came out from the exhaust, we did a compression test and cylinder # 1 was at just 95 psi while # 2,3 and 4 was at 110-115 psi. Again the piston #1 was covered with oil at the top. Engine was opened again and cylinders have the same mark on the back like if the rings are pushing harder to the back of the cilinders.is going out again but I can´t afford more mistakes, moreover I have to buy parts in the USA and bring them to my city in South America which make prices even higher. If any of you know or had this same problem, i'd be glad to receive your help. Thanks.
pd: i'm using now 7:8:1 standar compression pistons, 1.00 overbore.
