Chim55117
So the VR-4 is back up and running, although I'm still experiencing a problem I had before. Sometimes, if I start the VR-4 up, it will be idling very rough, although there is no CEL. When this happens it sounds like the car is running on 3 cylinders. Any attempts to give the car gas make the car stall out. Now if I go to the passenger side and reset the ECU, sometimes it will start normally and drive fine. Sometimes I have to reset the ECU multiple times for this to happen. This happens on and off, sometimes after a reset the car will drive fine for a day, or even a week, then it will happen all over again. The ECU that I have has no leaking caps, and is running DSMLink V2.5. Has anyone experienced anything like this, or know what this could be? Is it possible that the MPI relay next to the ECU is going out? Thanks for your help in advance, this problem is making me somewhat afraid to take the VR-4 out due to the fear of it running rough randomly.
