transmission tranx shaft play?
MellowVR4
Milwaukee, Wi
I recently removed my transfer case because im trying to hunt down this noise/ vibration, it will only do it under deceleration but now it does it all the time. i have changed the following thinking these can potentionaly be my problem. My driveshaft, driveshaft center support bearings, u joint, rear subframe bushings, and put a thick rubber bushing in between the exhaust and the diff thinking maybe my exhaust was hitting the diff that will cause that noise. Nothing, its still doing it, took my transfercase off and their was like three tee spoons of gear oil in it /ubbthreads/images/graemlins/dunno.gif /ubbthreads/images/graemlins/banghead.gif. Now would that cause the noise that ive been hearing? also when i took my transfercase off the shaft on the transmission wheir the tranx bolts up too had some in out play would this cause it? im replacing my transfercase soon see how that goes /ubbthreads/images/graemlins/dunno.gif. let me know with any advice that can help me with my problem please, thnx.
H05TYL
Wgtn, NZ
How much in-out play did the shaft have? It's possibly missing the ball bearing under the vcu that holds the shaft in place.
MellowVR4
Milwaukee, Wi
ill say about 1/4 of an inch in and out. maybe less
If your missing the ball, you could give that shaft a good yank and it would pop out. You should have less than 1/16 movement in and out.
Unfortunately, I still don't think that would cause a vibration problem. You would lose allot of oil out of the transmission though, if that shaft slides out to much.
I'm going to agree in that it is probably your t-case.
To fix your shaft, your will have to drain your transmission oil
Remove your outer case cover
Remove the snap ring that holds out your viscous coupler
Use heel bars to pry off the viscous coupler off of your center diff hat splines
As the viscous coupler is coming off, there will be two holes in your center diff hat splines, there will be a ball in one of these two holes and the steel ball is a little bit bigger than a BB.
Write back and let us know what you find.
That should get you on the right track.
If you have any questions, shoot me a PM and I will give you my number and I can walk you through it over the phone.
3rdstrikedsm
32159, FL
What clutch set up are you running? Unsprung solid disk?
MellowVR4
Milwaukee, Wi
Quoting BOOSTIN HARD:
thanks i will, im going to try changing my transfercase and see what happens.
MellowVR4
Milwaukee, Wi
Quoting 3rdstrikedsm:
im running a stage II zooom clutch kit. it is a 6 puck and it does have springs.
3rdstrikedsm
32159, FL
Well there goes my theroy /ubbthreads/images/graemlins/smile.gif Usally if you hava a solid clutch disk the harmonics will cause decel noise but this does not sound like the case here.
