So the trans is in my Galant. I am using the bracket for the shift cables from the 2g trans because with the GVR4 one cable will not go on to the pin due to alignment. Length is there but its some how kinked. I found that both cables were adjustable but one works so I left it. I adjusted the other and it seems to work. But any info on this would be great. A little too much back draw with side to side, if I take this out I loose distance forward.
Should I be using the 1g bracket?
Could I just swap the arm on the transmission? If so how?
