transfer case tail seal...
I know I need to. I noticed a puddle but when I went to top it off the transfer case starting overflowing like it was completely full. I'm not driving it in the meantime but I need to fix it before its a big problem. Did you check if you car had the recall yet? If not they are still warranting it but when I called on mine it was done in 1996.
Muskrat
Lexington, KY
I should be doing it this weekend. I'll elt you know how it goes.
The rest of the driveshaft rebuild has been a nightmare! Should have just bought an aluminum replacement, lol.
Toronto, ON, Canada
Most of the time it's not the tail seal but infact the driveshaft yoke cap behind the uni joint which leaks.
iron case transfer is much much stronger.
