AC Problem
Got a complete ac fan a few days ago to replace my non working fan. Before doing anything else I wanted to test the new fan to makes sure I didn't have to remove and install twice. Disconnected the ac fan harness left hand side of radiator I believe and plugged it into the new fan turned ac on and nothing fan does not spin. Since I got the fan from a member here I was confident that the problem wasn't the fan. So I connected the new fan to a jump pack and the fan came on. I checked the all the fuses and relays in the fuse box under the engine bay all were ok. The only thing I couldn't verify were those damn big ugly relays but they get hot and click when the ac is on so I presume they are working. Is there anyway to check these to make sure they are working? What am I missing here the ac works the fan just does not come on?
Thanks.
ktmrider
Tempe, AZ
So does the AC work but the aux fan does not come on?
BTW the aux/AC fan is the RH one when looking from the front of the car ( or drivers side ). Wasn't sure by your description below.
Yes the relay(s) could be bad, so could the sensors on the t-stat housing:
Yes the ac does come on but the fan does not come on. Yes I am referring to the one in front of car on the driver side. Seller assured me fan was in full working order guess I will have to find a way to check the relays and the tstat housing...
Quoting ktmrider:
So I guess I should start with the sensors. How do I test the relay though and are you
talking about the relay on the fan itself or the relays under hood in the fuse box?
MMCVR4
Once you test the switches/sensors, check the Auto Comp Controller, located behind the glovebox. click
Ok thanks so how can I test the switches or do I just change them all out voltmeter????
