Boost problem
The_Big_Weave
Rapid City, SD
Fixed my wastegate. now when i go WOT it takes a very long time to hit 10 pounds. 4k at 10pounds on a 14b is not right. and when it hits boost if feels slower then it was before it hit boost. Any idea what this might be? before it would sputter at around 15 pounds and pull right thro after that and had lots of power.
CarRacer
Shakopee, MN
Boost leak test would be a good move.
Barnes
Richland, WA
A) Double check that the wastegate arm is attached to the wastegate actuator.
B) Make sure your wastegate isn't doing what is pictured here. The red dimension marks where the bushing that the wastegate arm passes through started to come out of its hole. That offset should not be there. I had SUPER lag when this turbo was on the car. Notice that even though the wastegate is closed, there is still a large gap between the flapper and the wastegate hole.
http://img263.imageshack.us/img263/3998/failgateillustrated.jpg
check: vacuum lines and boost leak. i am betting on a vacuum leak issue.
TurboTrader
Pemberton, NJ
Pre-turbo exhaust leak? Cracked manifolds are very common. I have one myself, and I don't hit a full 10psi until around 4k, but it does pull hard to redline which leads me to believe you may have a combination of issues. The first could be a leak, the second could be the knock sensor going erratic. Once timing is pulled, you will feel a good loss of power. It is either real knock, or a faulty knock sensor. I would assume the latter. The black goo has a tendency to leak at the rear of the knock sensor and will make it become ultra sensitive and pull timing for no apparent reason. With the advice above, that should narrow it down pretty well.
