Does the diaphram have holes or torn? If not replace the fittings and try again. Just got done dealing with what sounds like a similar issue. Aluminum fittings and gaskets that came with WG did not seal proper so I used 1/8 brass pripe with a nipple on it and held enough pressure to open.
The only thing I cheaped out with on my setup was the WG. Yes, it is an ebay knockoff. But I have yet to see one that didnt work. You can test it with a simple hand pump. I used my penis pump.
Just to let you know, I'm a Urologist and I've prescribed and seen penile vacuum pumps used in what i thought were just about all the ways possible......but this is a new one for me.
