Would this cause a boost leak?
Brunoboy
San Bruno,CA Home of SFO
Hey guys, I noticed the bolt That goes into the tb to the intake mani has a crack on the end where it's in the mani, just wondering if it leaks air through there, it's a pretty big crack and idk how that happened.
Brunoboy
The Ed of the bolt that's inside the mani is cracke on te end, pics will be taken, it's just bothering me to think I maybe overlooked this the whole time
Nartanian
Richfield, MN
You can do a boost leak test. Otherwise if you have a boost gauge, check where the vacuum sits. Perhaps go WOT and see if there are any hiccups through the rpm band. If there is, that could possibly suggest there is a leak. Or just wait a bit till someone posts the answer.
jepherz
KC, Missouri
Quoting brunoboy:
wait, so the BOLT is cracked? or is the manifold cracked where the bolt is threaded in?
Brunoboy
Manifold is cracked not the bolt
