Ring Gaps
talon
Denham Springs, La
So I'm in the process of building the motor for the Galant, and I'm need some advice on gapping my rings.
I have a Tdo5 20g turbo that I plan on running about 25psi on once the motor is broke in. I've read that with higher boost applications you want .006 of gap per inch of bore. My calculations gave me .02, but an old timer told me that sounds like a set of worn out rings and got me worried.
So what do you guys think?
broxma
San Antonio Tx
I just finished doing a build and I gapped to .018. On all but one of the rings I didn't have to do anything. One came in at .016. I am planning on 30+ PSI once it gets running better.
/brox
Brianawd
Portland OR,
Kinda need to know what pistons you have, Stock or after market
ApexHunter
Marysville, WA
0.019"-0.020" top ring
0.023-0.024" 2nd ring
That's what i'm using in the engine i'm assembling now. It was a recommendation from another board member who reported those gaps to be successful for him in builds similar to mine (oem pistons/rings, s16g, pump gas). I actually ended up with 0.027" on the 2nd rings because that is what they came at....which was weird considering the top rings were pre-gapped at factory spec.
