JSchleim18
Continuing my journey to the most overcomplicated setup on earth /ubbthreads/images/graemlins/banghead.gif
I hate catch cans. Everyone has their opinions on which way is the best, etc. I have stumbled upon this product about a year ago and finally came around to looking further into it.
Mann Provent 200
The above link has a .pdf file as well to check out.
Basically, this thing is the size of most catch cans. However, the inlet and outlet are both close to 1" ID! (-16 AN fitting to give you an idea of how big they are considering most people only go as large as -10 AN on their valve covers). It has a filter in it which separates the vapors and has a nipple at the bottom which is supposed to be re-routed into the oil pan. This should be fairly clean oil but it's all speculation. It is a closed design IE no breather up top so it will keep the system under vacuum under normal operating conditions.
This thing is about $145 and replacement filters are $32.75. I don't mind paying the price as long as the system is correct.
Question I have:
Is one 1" fitting going to be possible to weld onto the valve cover and would one fitting be enough pressure relief?
-Thank you all in advance. If there is a proven setup that someone can chime in about that does the things the Provent can do I would be happy to put that into consideration.
Also want to add: Lingenfelter sells these as well under their own name: Lingenfelter
Mann Provent 200
Question I have:
