How can i tell if the diff i wanna buy is a true LSD, whats the number supposed to be on the 3bolt diff to make it LSD. looking to buy one just wana make sure.
Unless the rear cover has been changed out. Make sure that the axles are uneven. Also look in through one of the axle holes. There should be 3 splined regions on an LSD vs. just two on an open diff. The two outer splines are for the main axle drive and then there's a third splined region toward the middle which engages the secondary splines on the Driver's side axle and operates the LSD.
how do you change the rear diff pinion bearings, diff bearings, seal. i tried searching but i could not find nothing, just trying to change them before i put it back on.
