bazeng
Hi Guys.
Just a quick test for you guys.
I've wired up some aftermarket fans to my Brothers GALANT AMG. Now I haven't changed anything except for the fans.
So they are both running off the stock car loom.
Now, I just want to know what happens when you guys turn on your Air Con.
With the AMG, it just starts up the radiator fan (drivers side). The passenger side fan doesn't do anything.
I tested this on another Galant (JSPEC 88 model). It did the same thing. Drivers side one.
I tested this on another Galant (ASPEC 91 model). It fired up both fans.
So can you guys test this out and post up your results. I'm curious to know why / how.
Also the resisitor box, is it used to reduce the speed of the fan? I've tried by passing the resistor box on the Condensor fan without any change. The thing still doesn't run. I've measured the voltage but that didn't really help. I've yet to invistigate further. Any info would be great!
I also connected the stock ecu back into the car (currently testing with an aftermarket motec) and it changed nothing.
Please help!
Please help!
