Will Evo 9 Suspension work?
I tried searching for it but all the info was for evo 8 suspension. I know a lot of parts are interchangable between an evo 8 and 9, I was just wondering if evo 9 suspension will work the same as evo 8 suspension in a Galant vr4. I have a line on stock springs and struts with 18K on them for $200.
What about after market coilovers for the 7-9 after making the bottom end adjustments?
My issues I'd have is the quality of D2 and K Sport, and the fact that JIC is insanely expensive and rust super fast.
I'm running kyb adjustables shocks all around,and espellir lowering springs in front, H&R in rear, Tein pillow ball mounts in front stocks in rear.
I like the ride, great for autocross.
raptorWagon
Oak Harbor, WA
Quoting rost:
willn2speed,thats all from evo 9 right?Since the op asked about evo 9?
no, he is just stating what he has on his car as to the different setups that seem to have gotten mentioned in this thread.
Quoting 91VR41030:
8's and 9's are the same. You can use either one. The 9's MR had a better bilstein strut package though. Same mounts and same install procedure is needed. The EVO X is different, but not by much. I think there is someone on here working on figuring out if the X suspension can be used.
Diego
i got a set of E8's for free... im going to try em out.. i know Garfield sells the sets too..
Whoodoo
Binghamton, NY
I've got evo X front struts/springs with Ksport camber plates ready to test fit. But, no car here in NY is delaying a confirmation. From the pictures I've seen, the evo X rears are too tall.
Come on Tyler... get that car up and running so we can test fit these things!
