need help transmission removal
hi all, i have a 1990 vr4 galant my rear main is leaking and my clutch is slipping have never pulled a transmission from a awd car before.. if there is a thread with this info please point me in the right direction.. p.s i have looked for the past 3hrs but haven't beem lucky enough to find..
Polish
NE, IN
Go there ^, then click drivetrain, then click 1g AWD clutch swap. It's not a Galant, it is a 1g DSM however it's pretty much all the same steps and the trans/tcase/clutch is all the same.
Muskrat
Lexington, KY
I know I found one somewhere, when I did mine about 5 years ago. Can't seem to find it with a quick search. (right, clutch swap, duh! thanks Polish) But removal is easy:
cliff notes:
-Remove axle's and carrier bearing.
-Support driveshaft w/ wire or ratchet strap. Remove T-case Make sure you don't dump your gear oil when taking the T-case cout.
-Unbolt the transmission from the block and motor mount.
-Pry away from block and it'll drop out. Make sure you're supporting it, it weights about 100 lbs.
I'd highly suggest getting the $35 factory service manual on cd.
Getting it back in is a bit more of a bitch, so I'd suggest a hoist, or a few strong friends.
These types of questions really should be in the Newbie section.
mountaineerjeff
west virginia
I was really expecting a little bit different reply from polish, lol. do we need to link the video?
