I know I found one somewhere, when I did mine about 5 years ago. Can't seem to find it with a quick search. (right, clutch swap, duh! thanks Polish) But removal is easy:
cliff notes:
-Remove axle's and carrier bearing.
-Support driveshaft w/ wire or ratchet strap. Remove T-case Make sure you don't dump your gear oil when taking the T-case cout.
-Unbolt the transmission from the block and motor mount.
-Pry away from block and it'll drop out. Make sure you're supporting it, it weights about 100 lbs.
I'd highly suggest getting the $35 factory service manual on cd.
Getting it back in is a bit more of a bitch, so I'd suggest a hoist, or a few strong friends.
These types of questions really should be in the Newbie section.
