has some one installed these?
MellowVR4
Milwaukee, Wi
Has anybody installed these spacers that extremepsi sell for the driveshaft support bearing. they look nothing like OEM, each spacer is thicker then the other one, theres 5 for each side of the carrier bearing. /ubbthreads/images/graemlins/banghead.gif i need help i dont wanna install these wrong. heres some pics.
jepherz
KC, Missouri
They look exactly like the OEM ones, except they look to be made from aluminum. You're not supposed to use ALL of them, it's basically a grab bag of different sizes that you put in the high spots to make them lower. It's likely that you will have to double up on a few or buy a few of the kits to get it balanced right.
MellowVR4
Milwaukee, Wi
how would i kno if i balanced the driveshaft correctly. because i got 4 sets of these spacers because i need 2 sets for each bearing.
Its not for balance but for pinion angle. If you have an ipod touch or an Iphone you can get an app that has a level gauge that reads to 2 decimal points of a degree if not go to harbor freight sears etc and get a angle finder that has a 360 degree sweep. The one pictured below I've had for almost 20 years and in my opinion is more baller than the OLOA VR4 team Iphone design. /ubbthreads/images/graemlins/grin.gif
Dasco Pro angle finder
MellowVR4
Milwaukee, Wi
and im guessing that once i buy that tool it should come with instructions. on how to use it
Whoodoo
Binghamton, NY
Place it on surface in question. Needle is weighted and will point to whatever angle said surface sits at. (insert facepalm here)
H05TYL
Wgtn, NZ
Quoting MellowVR4:
who on earth reads instructions?
jepherz
KC, Missouri
Quoting jepherz:
Yeah, I wasn't thinking. I guess "balanced" wasn't the right word.
MellowVR4
Milwaukee, Wi
ok i got the angle finder tool, whats the pinion angle suppost to be?
jepherz
KC, Missouri
You're just trying to shoot for keeping the 3 sections of the driveshaft all on the same plane, so that under normal circumstances each joint isn't actually at any angle.
Like This:
Someone correct me if I'm wrong!
Whoodoo
Binghamton, NY
Quoting jepherz:
You're exactly right. Its all about angular velocity.
Oh I forgot... If you don't want to spend too much money on shims, you can use stainless washers, which you can find at any hardware store for cheap.
boosted_85
milwaukee, wi
Make sure that your doing your measurements on a level surface. Doesn't have to be complete 100% level but close. I usually put my car on a alignment rack that way it will be easier to read the gauge and easier to install the shims.
4thStroke
Vancouver, WA
Even if the surface isnt 100% level, he should be ok, since they will all be at the same angle relative to eachother.
