What size wastegate do you suggest using with a FP red turbo
4Grim
Orlando FL
I am getting ready to get the new turbo setup on #1948 and I am upgrading from a E3 big 16g to a FP Red turbo. I am going with a external setup and seeing those that are running or know anybody that are running a FP red turbo on their DSM/GVR4 what size wastegate they are running along with a FP red. I am looking most likely to run a Tial Vband wastegate and not sure if I should run a external dump or recirculate back into the exhaust.
Any input and suggestions would be greatly appreciated. /ubbthreads/images/graemlins/cool.gif
NateCrisman
Blairstown, NJ
Pretty much any Tial external will do. The new 38mm MVS wastegate from tial is Vband, very small (easy to work around), and relatively inexpensive. Mine held as low as 14psi on spring pressure alone without creep.
Junior392
Saratoga County, New York
I currently have an FP Red setup with an external 38mm Tial waste-gate. The 38mm is good for 2.5 BAR which is equal to 36.75PSI; Which I feel is plenty for this setup. I also purchased a 02 housing that recirculate’s the waste-gate right into the down pipe. I like it because it’s cleaner and not as loud as a dump. I believe that the 38mm is the smallest that Tial provides; but I haven’t had any boost creep with it.
