driveshaft carrier support bearing bolt?
MellowVR4
Milwaukee, Wi
has anyone had one of the driveshaft support bearings bolt strip, if so is this fixable, let me kno if you have had this problem before. thnx
Muskrat
Lexington, KY
Try re-threading it with a die (should be m10 1.25 mm thread pitch, IIRC). If that doesn't work you'll have to replace the stud. I'm not 100% sure what's involved in that, check the Factory Service Manual (if you don't have it, definitely buy the FSM CD. It's invaluable).
MellowVR4
Milwaukee, Wi
i was thinking, maybe i can take the carpet out then see if theirs a welded stud some were.
