Turbo feed question , how many of you set up like this?
Brunoboy
San Bruno,CA Home of SFO
I already know that the stock 1g had the turbo feed to the head, well I just blew my eBay 16g that was on my car when I bought it, and I just bought a big 16g from the for sale section. Well my past three months of luck wasn't great. I went through 2 14bs and that eBay 16g. I'm feeding from the ofh wiu a ss line and I figure that it'll be ok for my new turbo. My two 14bs blew because of my cat being clogged and one lost a exhaust wheel. The eBay blew seals. I'm sure the pressure was too high using 20w50 so now I'm going to use 10w40..... We'll beside all that a guy on tuners that I actually know is calling me lazy for not trying to relocate to the head, he actually said that when I blow this one he'll buy it from me because he wants practice on rebuilding it.... What a douche. My past 2g was fed from the ofh with a 14b so I see no difference. Anyways does anyone else run their trbo feed from te oil filter housing?????
-Shane
mikus
Aurora IL
I'd go from the head unless specifically instructed to do otherwise by the manufacturer or warranty provider.
91GSR
Newport News, VA
ive read that going from the oil filter housing can get u bad oil into ur turbo. by "bad" im not sure what it meant but thats what i read...in a book, not dar intarwebz
mikus
Aurora IL
^ the 'upper' available port on our OFH is just post-filter, it's clean as you can get.
Brunoboy
Geez hasn't anyone ran it from the ofh??? I'm pretty sure there is someone out there that runs it from there....
mikus
Aurora IL
i've run it from the OFH. It worked for my time with that turbo but I'd run it off the head if I did it again. The head feed is sufficient for almost any setup as long as the line is clean/clear.
On 1051, I fed oil to my FPgreen from the OFH, but it had a larger thrust bearing that required more oil. The ball bearing FP3052 that I run now requires lower pressure so I feed it oil from the head and I use a restrictor.
On 503 I feed my Evo3 16g oil from the head using a factory hard line. Works fine.
I suggest people that read things in books but aren't sure of the actual answer stay out of Technical Discussions threads such as this. It only leads to misinformation. TIA.
Ian M
Martinsburg,WV
I'd like to think Mitsubishi had it all figured out when they decided to feed oil to the turbo from the head.
fivestardsm
Middle, Michigan
Quoting Hertz:
/ubbthreads/images/graemlins/uhh.gif
+1
/ubbthreads/images/graemlins/rofl.gif
CarRacer
Shakopee, MN
Quoting Ian M:
Absolutely. They had it figured it out regarding journal bearing turbos, ball bearing turbos are a different story.
Mitsubishi also thought they had it figured out with stupid balance shafts as well. /ubbthreads/images/graemlins/rofl.gif
While I agree that the factory feed argument is probably best in this instance, I don't think such a blanket statement should be used for all arguments regarding our cars. /ubbthreads/images/graemlins/hsugh.gif
Ian M
Martinsburg,WV
Yeah I know,but we're (original post) talking about 14bs and 16gs here. /ubbthreads/images/graemlins/smile.gif
Haha,good point. /ubbthreads/images/graemlins/rofl.gif
Don't stop with just balance shafts though,there is more than one thing Mitsubishi probably coulda thunk out a little better. /ubbthreads/images/graemlins/wink.gif
Brunoboy
well if i do change to the head, i dont know all the fittings i need to convert the weird end of the ss that connects to the ofh to the round fitting, and i dont know what size bolt or plug i need to plug the ofh hole.
-shane
You can buy the a complete feed kit with line and fittings for like $20-$30 on ebay or just buy the one fitting if you really want to go back to feed from the head. IMO though I always run the feed from the OFH. I have ran 16g/14b's from OFH with no issues for over a year on multiple cars... /ubbthreads/images/graemlins/dunno.gif
Hertz
Chicago, IL
Balance shaft belts/bearings last more than a year too. /ubbthreads/images/graemlins/dunno.gif
Here is why I always thought was the reason people switched the feed line from head to OFH on 14b and 16g (or that type of turbo) cars. I used the OFH as a feed before on a car with a 16g and didn't have any problems.
Here
Click on the very last picture at the bottom.
Stock, the turbo oil supply is just about the last oil in the whole motor. If you get it at the oil filter housing, you get oil fresh out of the filter.
The head feed may be the last stop on the lubrication train, but an epic amount of 14b's and 16g's have gone hundreds of thousands of miles being fed from that location.
Rausch
Cleveland, OH
^ At least 4 or 5 for sure. /ubbthreads/images/graemlins/tongue.gif
Either way it should be ok. Journal bearings are not nearly as sensitive to higher oil pressures. The factory may have fed the turbo from the head because it was better, or because it was closer and cheaper. If you want to switch it, have at it, but it's just fine in the stock location.
