my rally vr4 dyno sheet..
jaska
Active member
Finland
here is my rally vr4 dyno sheet with 45mm recistor and 98 gasoline "pump gas in finland", i think at same for usa 93?..boost is 1.7 bar and then drops 5300rpm only 1 bar bacause my wastegate solenoid it´s something wrong, i must chance this with apex boost solenoid.my goal boost is 1.7 bar abot 5500 and then drops 1.5 bar all over the redline, because my exhaust back pressure goes to high.i´m very happy with torque..
jaska
Active member
Finland
692,4nm=509 ft lbs 4300rpm/wheel hp is 293.9kw=400hp and engine hp is 340kw=462hp with 5230 rpm..
/ubbthreads/images/graemlins/shocked.gif /ubbthreads/images/graemlins/applause.gif Mods??
VR4coop
Raynham, Ma
I assume its internally gated turbo so you need to fix that actuator. If its external just get a stiffer spring for the wastegate. Fix that boost and you will have even better numbers.
Clint
kaptainballistik
Sydney, NSW
Gee, why cant they let me run a 45mm restrictor! I can only use a 38mm! /ubbthreads/images/graemlins/applause.gif
Thats NUTS! /ubbthreads/images/graemlins/worthy.gif
jaska
Active member
Finland
mods.
fp3052 with 45mm recistor.tomei cams,haltech e6x,wiseco/carillo,1000cc injectors.
Thumbs up..... we need some videos
DR1665
Iowa City, IA
Quoting kaptainballistik:
Pfft! I dread the day when I have to install the 43mm the require here in the states. /ubbthreads/images/graemlins/banghead.gif
Tomei cams, eh? I was thinking Piper, but interesting to see others.
POST MORE, PLEASE. /ubbthreads/images/graemlins/hsugh.gif
EDIT:
Gentlemen, THIS is how these cars were meant to be driven! OUTSTANDING.
Quoting jaska:
here some rally video clips. web page
jaska
Active member
Finland
here new dyno sheet,spike boost 1.8 bar and then drops 1.4 bar..and now i use cyclone manifold,butterflyes open 4200rpm.looks like max torque is 400rpm sooner than before..
I love dyno graphs. i like to follow the lines and make the turbo sound.
There is srsly nothing cooler than the sound of a rally car flat out through the forest a 1/4mile away. The echo it makes is just plain sick.
Before the car comes into picture it just sounds evil: click
Quoting prove_it:
+1
PSHHHHHHHHHHHHHHHHHHHHHHHHHH
Whoodoo
Binghamton, NY
Quoting turbowop:
Even cooler than an F1 on the straights?
Baller /ubbthreads/images/graemlins/worthy.gif
