belt question
Brunoboy
San Bruno,CA Home of SFO
Hey guys, I also have to change my Power steering and Alternator belts. How long does it usually take to do? and will I be able to do it without a lift, and just jackstands and jack??? I need to finish it tomorrow.
Barnes
Richland, WA
Well. First time might take you a couple hours tops. You don't need to jack up the car. Helps to support the engine with a jack when you take the engine mount off. It certainly saves time not having to change the A/C belt, I don't like that on.
I can do it in 30mins or so.
Why do you take the engine mt off Jon?
ktmrider
Tempe, AZ
^^ It's not required to take the mount off but it sure frees up a ton of room to access both the PS and Alt belts.
Or better yet cut remove the "L" portion of the mount that goes to the front of the motor....
ktmrider
Tempe, AZ
Look here click for the mount mod description.
1990ggsxnj
Blackwood, NJ
Taking the mount off DOES make everything a hell of a lot easier. And that mod looks to be useful. If 2g's have it stock, I don't see any reason why not.
Brunoboy
hey guys, which tensioner does what? I was loosining one and it made the other one looser -___-
The alternator belt has its own tensioner on the alternator. The power steering is tensioned by pulling on the pump. The a/c has its own tensioner. You should not be affecting one with another.
Brunoboy
thats a good thing to know. I have worked on my 96 Eclipse GSX many times, its just that I have had help. and I forgot which one does what. Also I got a spare motor in the garage I was using as reference lol.
Barnes
Richland, WA
One sec. Maybe I'm senile. I *think* pull the mount off. Or maybe I don't.....
I dunno, try doing it with the mount in. If it is too hard, pull the mount off. /ubbthreads/images/graemlins/smile.gif
