Lifters?
johnnyRacer
Tampa, FL.
After soaking my lifters in Gumout carb/tb cleaner over night only one collapsed. I'm just trying to get it back to DD status for now. Any ideas?
Brunoboy
San Bruno,CA Home of SFO
buy the Topline Revised lifters for 109$ . =P
Barnes
Richland, WA
Did you use a small paper clip to depress the one-way valve inside the lifter?
johnnyRacer
Tampa, FL.
Yes. I let them soak overnight last night. I'll check them again shortly.
Rausch
Cleveland, OH
Make sure you are trying to depress them with the valve open... I know when I did mine it took some work to get them all to cooperate, some of the valves were very sticky, but eventually they all came loose.
I wound up working them in kerosene for a bit to get them freed up. Depress the valve and pump the thing a bunch while soaking.....Worked like a charm that way.
johnnyRacer
Tampa, FL.
Yeah, I'm begining to think the carb cleaner really isn't working well on these lifters. I was thinking of using either brake cleaner or kerosene. But I can get diesel the easiest.
