Idle and cut out issues.
deez
Chico, CA
I have two gremlins I'm gonna try to work out this week. One is the idle. When coming to a stop, the clutch goes in and the revs drop to 400-600, and it catches itself and gets back to where its supposed to be most of the time. Sometimes it dies. Sometimes it does what its supposed to do and goes down to 1100rpms, then when I stop it goes to 850. According to the logger, the reed switch in the speedo is working.
The other is a new problem. At 20psi and onlhy 4k-4500rpms, it cuts out. Lower boost, no problems. Other revs, no problems. I thought I might be blowing out the spark, but why would it only happen at those very specific revs and at high boost?
Thanks in advance.
Nabeel
K.S.A
Check these....LEAK, ISC, ECU.
