Removing inner valve cover baffles
89coltgt
Ste Genevieve, MO
How is the baffle removed and reinstalled?
jepherz
KC, Missouri
They are just installed with some metal cylinders that are sorta mushroomed on top. I removed and reinstalled one by welding on aluminum tabs along the sides. I have also seen others install sheet metal screws and tack them to the baffle. The problem is that the cover is aluminum, and the baffle is steel.
bustedsm
Ripley, Tennessee
John, spot weld and then crush the weld onto the baffel that way it will stay put.
stevep
St. Charles, IL USA
Don't use screws. Having one drop into the valve train would spoil your day.
The original castings have "rivets" in them that they mushroom when they install the baffle.
pachood_1953
eau claire, wi
Do they NEED the baffle? I have a spare VC I was kicking around the floor for months and it got all full of sand. No matter how much I clean it, I still wouldnt be comfortable putting something on that may have sand hidden somewhere..I'd like to get it powdercoated or something since its pretty much mint IIRC.
866galant
Active member
TX port arthur/beaumont
i sent mine out to get powdercoated and removed the baffle, i would like to know if i could keep it off too
powerplay
Norwell, MA
There are two separate chambers under the baffle. Here are a couple of pics. I don't think it would be a good idea to leave it off.
14u2nV
Agency/St. Joe, MO
Isn't the baffle just there to give you some air space for the pcv valve so it doesn't suck oil? If you have a catch can, I wouldn't think you would need it, though you may be emptying it more often.
G
zompton
Why are you thinking about removing them & reinstalling?
EMX5636
Bucks County, PA
Quoting 14u2nV:
This is pretty much right. You need some sort of baffle in there to keep from filling your catch can (I've seen one fill within a day or two without baffles in). Worst case if you can't get the stock ones in, just build a flap to cover most of the port out of aluminum, and have it tacked in. But you should have something there to keep the oil from being blown/splashed out.
Justin
Polish
NE, IN
My friend tried to run without one (Baffle), Catch can was full in like .5 seconds.
Highly NOT recommended.
bustedsm
Ripley, Tennessee
Corey, was he running anything larger than the OE vent ports? If so, that's why. I never filled up the cans once with the -8 lines on the cover and no baffles.
Polish
NE, IN
No, just hoses clamped to a gutted PCV and the stock breather port.
It could have been a week or so, I don't recall but it filled fast. His motor was a little sloppy though, had some blow by and such.
Either way I do not suggest it. /ubbthreads/images/graemlins/smile.gif
bustedsm
Ripley, Tennessee
That's why! The stock PCV system on an unbaffled cover will blow oil into the cans without hesitation because it's a much smaller space for the blowby to occupy. Like I said, it's different with the -8 fittings on the cover, but it's really owner's choice.
89coltgt
Ste Genevieve, MO
Quoting G:
I was planning to weld in two -8 an bungs on the vc so it really needs to be disassembled in order to do this.
