Where to get t-body rebuilt?
3rdstrikedsm
32159, FL
any suggestions? I would like to go oversized. And I will double check and stake the shaft screws per Terry's problem. I guess I learned a valuable lesson from that even though it sucks that it had to happen that way.
atc250r
Orange County, NY
Polish
NE, IN
I do not get why people don't do this themselves. It is so freaking easy and saves so much cash. DIY gets my vote.
And the slight bit oversized is a joke imho, just leave it.
There are 2 throttle bodies for 4G63's. Stock or if you make big power the Q45 tb.
jepherz
KC, Missouri
I'd agree with you polish, but he also mentions he'd like to go oversize. Normally "rebuilt" just means replacing the seals.
steve@ throttlebodies.com did a awsome job on mine..
went with the over bore to a 63mm.. checked all the sensors and only had to replace the off idle switch, but everything else was a 100%. It does stick a little bit but i figure i just need to drive her hard and it will fix itself.
Polish
NE, IN
Quoting jepherz:
I also soaked mine, got all the grime off, cleaned/tested the sensors, readjusted them to give proper readings, MADE SURE IT WAS GROUNDED (Gtluke ftw), new seals, cleaned the spring deal (It was caked with crap), and so on.
I saw the oversize mention but I think it's a waste and very dangerous, not worth the risk imho. People here and on the DSMlink board have had the screws come out and F the motor, not cool.
Just my .02.
Nothing wrong with Steve and many people use his service, I just don't see it as needed. /ubbthreads/images/graemlins/smile.gif
4thStroke
Vancouver, WA
Are there any TB rebuild kits sold online? Or is it just piecing the parts together separatly?
I messed up my TB shaft trying to get one of the screws out, anybody got one laying around? I may just drill and tap, but if I dont get it exactly right, the valve may not be centered as well as it should be.
3rdstrikedsm
32159, FL
I wonder about the screws and what plate he uses? Terry did he rebuild and bore yours?
iLLeffeKt vr-4
NYC
My NT throttle body was rebuilt and bored out by Steve. Awesome job and will do it again if I have to.
Hksvr4
NYC
Steve does a Awesome job and will do it again if I have to.
Fixed.
mooserage
Seattle, WA
Steve does an Awesome job and will do it again if I have to.
Fixed.
/ubbthreads/images/graemlins/smile.gif And yes, he definitely does, I love his work, worth every penny.
3rdstrikedsm
32159, FL
I have chosen to rebuild it my self and not go bigger with the bore, I just can't risk loosing 8k worth of motor and turbo from a 15 cent screw.
stevep
St. Charles, IL USA
Then make sure to stake the screws down when you put them back in.
Don't over clean the butterfly, the gunk around the shaft area on the backside it to help seal it. Make sure to remount it exactly the way it was or you make have problems getting the idle right. It doesn't take much extra air leaking past to cause surging and high idle problems.
Luke
San Jose, CA
