Differences between evo 3 & 2g head?
G
zompton
Has anyone actually had them side by side to notice the differences? I wonder if the part # for them is the same, though i highly doubt it.
G
zompton
I found these pics of evo3 heads. Can someone with caps working cross reference this part # for me for u.s. applications?
jepherz
KC, Missouri
I'd assume they are closer to 7 bolt heads than 6 bolt ones, no? That number doesn't come up in my caps.
3rdstrikedsm
32159, FL
Ports are slightly diff but other than that very close to the same, I have had them side by side.
ktmrider
Tempe, AZ
Hit up Alex/Bimmubishi, he has both around...
G
zompton
click Check this out. So i wonder what the difference is with the 97'~99' 2g heads?
atc250r
Orange County, NY
Link isn't working.
You can't give too much validity to the part numbers found in CAPS and on lookup sites. Sometimes when you enter the part number at the dealer to order it the number changes to a cross referenced part. The number for the older 2G heads might supersede to the one for the newer ones.
John
CarRacer
Shakopee, MN
Ones JDM, one is not. That should make the decision east for you G.
/smart ass answer
G
zompton
Crap type the # in & it says it's for 95~96' 2g turbo & a 94' 2.4 liter. I'm looking to buy a evo3 head. But if it's the same as a 2g that will save me a ton of money. So if the evo3 head is the same as a 95~96', then what's different about a 97'~99' 2g?
G, they are so similar that I doubt you are going to see much of a differance. I would just get a 2g head for $50 and call it good.
G
zompton
That's probably the route i will go, but still curious about the 97'~99'.
Wizardawd
Franklin, NC
Probably has to do with the fact that 95-96 had the holes tapped for the cam sensor behind the intake cam gear, 97-99 had a cam sensor in a similar location to a 1g.
That's my theory.
Wiz
G
zompton
So to make for a smooth head swap i should go with a 97'~99?
Wizardawd
Franklin, NC
Far as I know, any year head will accept a 1g sensor with no problems. But, if using the 95-96 style sensor setup (not sure why you would...dam things get brittle and break all the time) the bosses are only there on the 95-96 castings. Again, my theory...don't have a head off a 95 to compare.
Wiz
CutlassJim
Manchester, NH
I have a 95 head on my car and minus boring out the head bolt holes a smidge it was a complete bolt on deal.
G
zompton
Nice. I double checked with mmna & they say the above part # is for the 1/95 TO 11/95 2.0 dsm TURBO only, but it also looks like the evo 3 head as well.
