how much fuel pressure?
I am currently running a TO4B turbo, Wally 255HP fuel pump, FIC 550CC injectors, and 24psi. I just installed a adjustable FPR and was wondering what amount of pressure I should be running? Any suggestions?
steve
NJ
Stock (37-38psi)
iLLeffeKt vr-4
NYC
37psi with the vacuum line off the regulator.
Quoting iLLeffeKt vr-4:
You meen set it with the vacuum line off and then put it back on when it is at 37psi?
Quoting B00000ST:
A lot depends on how you are compensating for the 550's. If you have the ability to compensate for large injectors properly (DSMLink, chip, etc) I'd recommend going to an even higher base fuel pressure, to stretch those 550's a bit more. The Delphi 550's tend to run
I am just using a MAFT V2.0 and I wanna get my my ECU chipped. The car is still running a little rich even with it at 24psi. I am going to hook it up to a logger and see what kinda knock I am getting this week. Its not like I am constantly beating the crap out of the car. I only drive it like 1-2 times a week.
CP
West Simsbury, CT
Jeff burned a chip (one of many) for my setup, and then had me mess with the fuel pressure until my HIGH trim was near 100%. Then I adjusted the SAFC until the low and mid trims were close to 100.
